Painting floor
TexomaAv8r
I have replaced the floor in my storage shed with 3/4 ply on 2x6 joists. What should I paint the floor with? It will be primarily storage and some lawn equipment
Bob_VT
Re: Painting floor
You could leave it alone or just use some porch and deck paint if you insist on painting it. I doubt it will see enough traffic for an epoxy paint.
TexomaAv8r
Re: Painting floor
I might do that> I wasnt sure of dragging lawn mowers etc across it would be bad or not
Chief101
Re: Painting floor
I know thems what uses a garage floor paint from Rustoleum. Hold up perty good. At least the oil spills wipe clean easily. Chief
Haut Medoc
Re: Painting floor
Epoxy, it is impervious to gas & oil, and really holds up....JK
ndemge
Re: Painting floor
Haut... they do make epoxy paint...., <br /><br />Do a google search for "plywood aquarium" and use what those guys use to paint those things.
RPJS
Re: Painting floor
probably a bit late to mention this, but I would paint the underside of the floor with some sort of preservative it stops any damp getting at it.
Ron G
Re: Painting floor
Im with bob for a srorage shed,you could but thompsons water seal on it then wait 3 weeks and put a solid color stain on it,its cheap and easy to do,and you can redo it every couple of years.
