magster65
Thread starter- Joined
- Sep 1, 2002
- 2,573
Re: Pardon me Don S...
Yeah, I'm familiar with 'heat soak' but this isn't an alpha, it has the bravo set-up and I put a new impeller in it to kinda' rule that out... and you're right, my other boat has the alpha setup with no problems.
I'm gonna' borrow an infra-red temp sensor and see if it's a 'hot spot' at the sensor or if the engine really is warming up... but I kinda' doubt it is.
It doesn't feel hot and the temp guage goes up and then back down pretty quick... I don't if it's actually possible for an engine to change temperature that rapidly?
its called heat soak
its also not helped by the stock alpha seawater pump.
while not every boat does it its rather common to see on freshwater cooled boats.
Diesels will do it as well and its why they reccomend an idle period to stabilize egine temps before shut down.
you will find a belt driven seawater pump and a through hull pick up will cure most of it, however as long as you keep the stock alpha setup in top notch shape it will work with no worries.
that setup has a lot of heat built up during the 3500 RPM plus range then is suddenly dropped to idle.
at idle not only does the engine circ pump slow down but so does the pressure from the seawater pump. takes a min or two for the liquid to liquid HE setup to catch back up.
most cars will do the same, shut off the engine and imediatly turn the key back on and you will see the temp climb with the engine off for a few minutes.
190* is still within the operational limits of the 5.7.
