Pawl Springs for Johnson HD-20/HD-25's
1946Zephyr
Recently, a member posted a thread here, who made the pawl springs for this model motor. If someone could let me know who he is, I would like to purchase a few sets.:cool:
F_R
Re: Pawl Springs for Johnson HD-20/HD-25's
Go ask the queston on the Ask-A-Member forum at aomci.org Garry will post the instructions and you can make your own.
kbait
I found a workaround at the local hdwr. Same diameter spring, but too long. I just cut 'em down, bent new ends, and they work fine. I called a marina to order some a few years back and they were available, but WAY expensive, so I made my own.
Chinewalker
I've made them from stainless guitar strings...
kfa4303
Banned
Cool trick. What kind of guitar do you have/play? Guitars are my first love.
1946Zephyr
Cool. I found the forum, where a guy described how to make them.
I may also explore the option of retro-fitting the starter assembly, like I did on my Zephyr. There, I just replaced the pulley, with that from a 1954 Johnson 5.5hp (376377) and I mounted the ratchet (202111) in place of the older starter pawl assembly. I had to shim the ratchet up .100, but it worked like a million bucks.
The earlier JW's may have the hardware that will work to retro-fit my HD.
1946Zephyr
From what I see, it just takes the .016 guitar string and each string will make about 9 springs.
