Peak reading tester
roach
Any suggestions for a peak reading meters? Brands/models that don't cost an arm and a leg /
Thanks,
Kevin
dingbat
Re: Peak reading tester
How fast does it need to be? Most of your less expensive meters have relatively slow capture times.
Thanks,
Kevin
Hi Kevin
Which peak reading are you wanting? I could guess it may be volts but there are other variables. The more accuracy you want the more it will cost. There is peak volt reading of AC and Root Mean Square (RMS) measurement. Please expand your question
roach
I have to do some voltage readings on my Johnson to troubleshoot a possible bad tach.
This is done with the ignition on and the motor not running. I have an older Fluke digital
that shows about 2/10 of a volt difference between the battery and under the dash at
a test point. Does this help or do you need more info. I am at work and cannot remember
the Fluke M#.
Thanks,Kevin
Silvertip
Sounds like you are checking battery voltage. You don't need a peak reading meter for that. You need the DC setting on a standard multi-tester. 2/10 of a volt DC drop between the battery and the "I" terminal on the tach will not affect tach operation. You have other issues such as a bad tach or a bad rectifier. The tach for an outboard counts pulses from the charging system which is an AC system. In the case of a Johnson the charging system has 12 poles which as the flywheel rotates creates six pulses with each revolution. It is those six pulses that the tach counts. Using this technique, the tach can be used on any engine whether it has one cylinder or a hundred -- as long as the tach can be set for the number of pulses/rev for that engine. The pulse or send signal from the charging system is the gray wire in the harness and it originates at the voltage regulator on the engine. If the engine isn't charging the battery, then the regulator is likely bad and it also accounts for why the tach doesn't work. Measure battery voltage with the engine off. Now start the engine and set rpm up to about 2000. If the voltage on the battery doesn't rise above 12.6 you have a bad charging system.
UncleWillie
... If the voltage on the battery doesn't rise above 12.6 you have a bad charging system...
That is technically correct.
Expect to see WELL above 12.6 with the engine running.
If you do not see at least 14 volts, there is a problem.
roach
I have a 1997 TSLEUA 90 hp 6amp unregulated system. I have never seen the voltage above 13.1 or 13.2 volts when running
other than when the rectifier was bad. If the charging system is bad. I will have to buy a new stator .
FYI, Roach
UncleWillie
FYI, Roach
Depending on a bunch of variables; A typical Lead acid battery will only begin to take the smallest of charge at ~13.8 volts.
13.2 indicates that one or more of the rectifiers are bad. 14.5 volts is a typical engine ON voltage.
bruceb58
As that what you see at your gauge or measure with a multimeter at the battery?
roach
Thats the voltage I read on the volt meter on the dash.Also on my Lowerance HDS unit I can get a voltage reading of a little
over 13 volts when it's been running.
FYI,
Kevin
FYI,
Kevin
Dash gauges can be off quite a bit. Have one which is showing about 12.5 but put my meter to the same contacts on the back and I get around 14
roach
Looks like I am going to have todo some more measurements. I have an 8020A Fluke.
Will voltage increase with rpm increasing or just amperage?
Thanks,Kevin
Thanks,Kevin
They can and do increase, but don't worry about amps, just note the voltage increase
roach
So back to the original question. Any suggetions for a peak reading meter. Don't want a Caddilac.Don't want a Yugo.
Thanks,Kevin
For a true RMS meter which is built to take a lick'en I would suggest the Klein MM2000
bruceb58
If all you are measuring is DC, doesn't really matter if you have a true RMS meter. RMS meters are only necessary if you are measuring sine waves.
If you are trying to measure and hold values of voltage spikes, not many meters have the sampling rate to actually catch them.
dingbat
Sounds like he's confusing peak reading to peak hold. If he really needs a DVA it would be cheaper to buy an adapter
Hey, the OP asked for a good peek meter, so I offered one. Not wanting to try and clarify again
bruceb58
I was thinking the same. You can make one very easily as well.
roach
So how do I make an adaptor for myself? Thanks,Kevin
