Well they say there are no stupid questions? I have a 1991 25hp....thanks
M merc25rules Cadet Joined Apr 19, 2009 Messages 24 May 13, 2009 #1 Well they say there are no stupid questions? I have a 1991 25hp....thanks
airframer Petty Officer 2nd Class Joined Nov 10, 2007 Messages 158 May 13, 2009 #2 Re: Pee Hole-Should water be warm slightly warmer than whats going in
F fasassvalk Seaman Joined Apr 2, 2009 Messages 59 May 14, 2009 #3 Re: Pee Hole-Should water be warm Mine is always luke warm
M MotorlessCSJ16 Seaman Apprentice Joined Feb 9, 2009 Messages 47 May 14, 2009 #4 Re: Pee Hole-Should water be warm If I run mine wide open or cruise it'll get pretty hot. And that's with a new water pump. At idle, warm. I have a 1998 Merc 25.
M merc25rules Cadet Joined Apr 19, 2009 Messages 24 May 14, 2009 #5 Re: Pee Hole-Should water be warm mine is more than warm but not hot....def warmer than the water it is in. maybe a new water pump would help
J JerrfyLube Seaman Joined Jan 16, 2009 Messages 53 May 14, 2009 #6 Re: Pee Hole-Should water be warm It should be a little warm...how warm is dependent on how well the engine is running, ambient temperature of the air and water and how well your cooling system is working. As long as its not getting hot to the touch, you should be fine.
M merc25rules Cadet Joined Apr 19, 2009 Messages 24 May 15, 2009 #7 Re: Pee Hole-Should water be warm thank you sir i appreciate all the replies
