penta 280 problem shifting between forward and revers
FOuR BuOYS
1981 campion 24 Haida
5.7 lt engine 280 leg
We have just bought this boat, so we are not sure on what is normal or not. The leg lift a bit in reverse and then bumps down hard when put back in forward is this normal. :confused::confused:
Don S
Re: penta 280 problem shifting between forward and revers
No, it's not normal. Sounds like the reverse lock has problems. Either it's worn out, dirty, or corroded.
You can download the OEM manual Here
Go to the section starting on page 75
FOuR BuOYS
Thanks Don
You guys know your stuff.
