Petrol smell????
jak2108
We have a mercruiser 4.3L and there seems to be a strong smell of fuel when idling. All fuel lines have been checked for leaks and are OK. The plugs have been checked and have no signs of fouling due to richness. Any ideas or is this normal
jerryjerry05
Re: Petrol smell????
No not normal.More info please??Carb or EFI,profile filled out.
Check the oil see if it has gas in it.J
180shabah
definitely not normal, you need to find the source before bad things happen.
Fishermark
As Jerry mentions - check the oil for gas. If you have a mechanical pump, the diaphram can rupture and put gas in the oil. Otherwise.... double and triple check all the fittings - including the fill and vent lines.
Flyin1500
If you do get gas in the oil, is the only way to tell by smell, or will the oil look different?
Gary H NC
Depends on how much gas may be in the oil. Smell is the first check.
If it smells like fuel check the stick to see if the level is over full.
Also there should be a small plastic hose from the pump to the carb,(usually clear or yellow plastic)Check it to see if it has traces of fuel in it.
If so the fuel pump is bad.
Fishermark
That's true, but I believe they can also rupture internally and not leak out from the tube to the carb.
cr2k
That hose is the vent so if it does rupture it will show in the tube.
We had a boat last year that wife keep saying she was smelling gas.
Turned out she was sitting by the tank vent fitting on the hull. If you are idling and maybe wind at the stern, this could be your problem.
