We have a mercruiser 4.3L and there seems to be a strong smell of fuel when idling. All fuel lines have been checked for leaks and are OK. The plugs have been checked and have no signs of fouling due to richness. Any ideas or is this normal
As Jerry mentions - check the oil for gas. If you have a mechanical pump, the diaphram can rupture and put gas in the oil. Otherwise.... double and triple check all the fittings - including the fill and vent lines.
Also there should be a small plastic hose from the pump to the carb,(usually clear or yellow plastic)Check it to see if it has traces of fuel in it.
If so the fuel pump is bad.
