jerryjerry05
- Joined
- May 7, 2008
- 18,174
If you buy the regular ones?? Then use duct tape to seal the edges. The tape needs to be put on before the motor gets wet as it won't stick very good.
Bowl had a later ov varnish in it. Needle was stuck which released on contact with the spray. There were a few spots that didn't clan off when sprayed that the soak cleaned just fine.The float bowl will show what condition the rest of the carb is in. If?? it's real dirty and corroded?? Then the jets and other parts will be that way too.
Most times the spray cleaners work just fine.
I did pick it up alone once, to adjust it on the motor dolly. Paid for it later though.I can not pick up a 30 hp anymore.![]()
