Re: PING
SBN, one idea on how to get it to work. In some versions of Windows, I have experienced what you have here. A way to get around that is to create a shorctut to do what you want. This lets you set some options up front. Usualy, if a window stays up long enough, you can right click on it and it will let you set some oprions of which close when done or on exit one of them. Unfortunatel, the window may close to quickly to get this done. To get around this, create a shortcut then right click on it to set options for the PIF (Program Information File).<br /><br />1. Right click on the desktop and click new/shortcut.<br /><br />2. In the path, type the word command.<br /><br />3. Click next, give it a name and click finish.<br /><br />4. Right click on the new shortcut and uncheck close on exit.<br /><br />5. Click ok, then try it out. You may want to even type ping and then your site to run the ping automatically, then it should stay up afterward. <br /><br />Just a thought.
