Piston damage
Nordin
Most of my rebuilds of Force/Chryslers I have reused the crank seals.
Inspect them and be careful when reassemble the crank in the crank case.
They are really easy to snap if they do not line up in the groves.
jerryjerry05
Only replaced them if they were broken.
When reinstalling, I make sure the opening of the ring is placed down so when the
covers installed the seals push down and seal.
A wire brush on a drill, clean the mating surfaces.
Don't overdo as the brush can eat into the soft alum.
RTV on the bottom bearing making the seal.
Can't tell was there sillycone on the center bearings??
Doesn't need to be there.
The Force power
thank you
The Force power
Thank you Jerry,
I have the proper tools for cleaning aluminum surfaces ( did a lot of oil-pans/head-gaskets on Isuzu/yanmar engines)
No Silicone on Center-bearings or locktight
The half joint on an outboard is precision.------Only use ---Loctite 518---as a sealer.-----It has no fillers and most if not all should squeeze out.---Do not put sealer on bearings !!------That gets you the proper " clamp up " of the bearings.-----You do not want bearings loose after assembly.-----That just spells $$$ / time wasted
The Force power
Noo, I would never put silicone on any bearings, but are saying not even on the two half pieces of the block? just loctite?
Do not use silicone !------Use Loctite 518 or a product called ----" gel seal " ----From your local Johnson / Evinrude dealer.
jerryjerry05
The bottom bearing has a locator pin.
The silicone is just for the seal.
It does go on the 2 half's of the block
The Force power
That's what I was thinking, a thin film of form-a-gasket between the two half & loctite on the top main-bearing only because all the other bearing have a locating-pin and can't spin anyways
jerryjerry05
The factory used sillycone on the top bearing and the mount for the trigger/stator.
jerryjerry05
Never saw one there.
It doesn't show on a parts diagram either, at least none I've seen.
The Force power
Okay, I think I found my first "melted piston" & I also found the exhaust-ports in the cylinder-wall have crack in them.
I'm not sure how to measure a Piston's diameter other than with a Caliper, but how do I translate that into 0.10 /0.20--0.40 IMG_2130.JPGIMG_2125.JPG
you bore the block until it cleans up and measure...... only after you have the block "rough cut" do you ever order pistons.
then you hone to finish dimensions
The Force power
Hi SD, thanks for tuning in
I'm not going to re-use the block, I have a block ( same diameter/size) that the cylinder-wall are in good shape.
I tore this one apart to pull out the "good piston(s) but I broke the top ring on one of the good piston.
I think these piston are originals as they have pressed-in pins.
To make a long story short; I need to find one top ring for this piston so I can transfer it into the other block.
So how to I measure the piston to find a suitable ring for it? or will that be impossible and just have to look for a complete piston that size?
But even then I need to know the size to find a good used piston
The Force power
Sorry!!
I am an idiot :frusty::frusty: this information has been give to me already
