Piston damage
atengnr
I will note that the pics above that show the exhaust ports show cracks just as my 70hp had.
The Force power
Hi atengnr,
I remember reading that in your post. I'm curious to what that would have caused? maybe it is caused by over-detonation or just a bad cast
:noidea:
atengnr
Yeah i dont know if this is occuring just in failed cylinders or even in cylinders with normal wear. Id have to suspect a design issue since i checked 2 blocks that I had and both had cracks in the ports. But dunno.
jerryjerry05
From wat I understand?? the timing being off or using premium fuel and running too hot could contribute to the cracks
The Force power
Yup, it has cracks in the next one over where the piston is not damaged.
logic would dictate the piston is not (necessarily) the cause
Should be no issue finding that in the GTA area.------No problem for me to find either one !!
