snowbrd84
Thread starter- Joined
- Sep 23, 2012
- 215
Took the boat out this weekend for the first time with the new to me '86 Mercury 150 XR2. It seemed to be running great although there was some hesitation and every once in a while i would hear a strange clanking/knocking sound that I though was a misfire. The 150 on my 18' bowrider absolutely flew, scary fast. All of a sudden, horrible castostrophic banging/clanking sound at 3/4 throttle, kill the motor. Long story short, get it started back up and limp home with basically no power and it would die if given any throttle.
I start it up the next day and it seemed to run perfect, no sounds. Run compression check, 115-120 psi on 1 through 5, but then 0 on #6. Pull the head and found destroyed piston on #6, see below. So there is very very light scoring on the cylinder walls, can barely feel it with my finger and cant see it with the naked eye.
Here are my questions:
1) Since the scoring is so light, is there any way I can just hone it and throw in a new piston? It was scary fast with 5 cylinders, as long as it wouldnt cause it to fail again, does it absolutely have to be honed? I am out of budget at this point and cant really afford that shop bill...
2) What other things should I look for damage wise? I have most of the motor off and I will be pulling the power head tonight to crack it in half.
3) I am trying to figure out what caused this damage, it was not running hot and it definitely had oil. I did replace the stator and a switch box prior to taking it out. Could the stator or switchbox have caused detonation resulting in this?
4) Any general tips or suggestions on the piston replacement? I never replaced a piston before, but I have stumbled through a good deal of engine work. I do have the Seloc manual and I will be using that to assist.
