I have previously, given you my opinion on a prop choice and,
Thanks for the pics, but I'm confused, it looks like there is some type of "notch", "tunnel", in the bottom just before the prop, that might be causing some type of turbulence when you try to get on plane? I wonder if your cavitation plate needs to be flush with the top of that tunnel, or notch?
But, that don't seem right either, hence my confusion
Water is naturally going to fill in that tunnel, and flow over your cavitation plate at low speed, and as you try to plane, creating a problem IMO, but once you're on plane, the tunnel would be out of the water,,, I think?
But, having that trailing edge of the tunnel so far ahead of the prop, means that the flow of water will rise some from there as you're on plane (as normally happens from the trailing edge of any boat), that might be restricting flow, causing too much going over your cavitation plate, creating a restriction unless you raise the motor up some.
