Planing question
Re: Planing question
I'm trimming the motor pretty much down,
Ayuh,... I ain't sayin' this is your Problem,...
But,...
Gettin' outa the Hole works Best with the motor trim Fully Down,... Then trimming up as needed..
high'n'dry
I'm am def not an expert, but I am pretty sure I read somewhere that trim tabs are not to be used to get on plane, only to offset chop. I think it mentioned trimming them down to get on plane puts stress on the engine. could be wrong.
Well, they are wrong.
767Captain
There's your problem - you have too much pitch on the prop. WOT rpm is how you figure out if you have the right pitch or not. My guess is that Dingbat is exactly right. Your typical operating weight is probably more than you think it is.
"Kick the tires and light the fires - it time to do some yankin' and bankin'! No wait! You can't do that in a 76!" ;)
Sure you can, more so in the 757! Best commercial plane in the fleet.
OK, to wind this up;
Best of Thread award goes to Dingbat. Solid advice from someone who has the same type of boat / engine that I have. Thank you. Thanks as well to the other responders, your input is truly appreciated. I'm picking up a couple four blade props to try out from a good local shop. Working on reducing gross weight, but with the holidays and all... :D
jay_merrill
This is true - you could prolly do the Bob Hoover trick with the glass on the dash too .... but, the pax might get a little upset!
Texasmark
jay_merrill;2428 regardless of material. ???[/QUOTE said:
Sorry man but you are absolutely out in left field on this particular comment. BTDT
Mark
