kentuckydiesel
Thread starter- Joined
- Jul 11, 2012
- 48
I had been having some ventilation issues but after some adjusting the steering link between my two outboards and adjusting the tilt, I have the ventilation under control.
Still having issues with the engines overpowering the props. Trouble is, with four people in the boat, they are still overpowering the props so much that it's hard to pin down how much prop I actually need.
Engines are 3cyl 70hp Johnsons, one a 1974, the other a 1981...Props are 13.25"x19". Boat is a 1961 lone star 23' with a warped planing hull (sharp deadrise at the bow, "nearly" flat in the stern). Weight of the boat/outboards should be around 1500lbs. I went ahead and figured on adding 1000lbs of people and gear just to be conservative...though the boat would likely be running around 2000lbs most of the time.
Look at these numbers:
According to this calculator, with the boat weighed down with 1000lbs of people and gear, I should be able to hit 59mph with the 140hp generated by the two 70hp outboards.
I am currently having to be very careful not to over rev the engines because the props aren't loading them enough, so this seems correct.
Now the prop calculation. BTW, I entered the 59mph into both speed and theoretical speed...though I am almost positive that I need to use actual speed.
This is basically telling me that I need a prop with a 27"-30" pitch.
While that would be fine with me...I can't seem to find any props available for the johnson 70s over 23" pitch. Anyone know if that might be because the little trim tabs are in the way?
What do you guys think? Does this all seem logical? Remember, even though there are alot of 23' boats out there with more hp running less max speed, this is a very light dry hull.
Thanks,
Phillip
Thanks,
Phillip
