EHouseHead
Thread starter- Joined
- Sep 5, 2009
- 53
Re: Please help asap! First a collapsed fuel bulb & now just "click" when i turn the
I tried the jumper cable trick it just sparked. I hit the starter with a hammer the other day and it turned over and ran for a few, I turned it off and went to start it again and it sounds exactly like a car trying to start with a dying battery however both batteries check out fine. I have only had the boat out a couple times. I personally haven't gotten into the rough stuff, my friend who owned it before me said they got caught in 6-8ft on the way in once and it handled like a champ. Didn't even take on water. I think I topped out around 37mph (the speedo needle is broke so I was using gps)...
As noted above, a cascade of events. Bad anti-siphon, no gas, a ton of cranking and starter is toast.
You can buy an aftermarket starter and save money vs. BRP (under $100).
Using a jumper cable to apply 12v directly to the starter nut(avoid the threads) is a simple test (you may have already done this).
Curious, how does that 2150 handle the rough stuff and what MPH do you top out at with the 175?
