Rick paredes
- Joined
- Sep 8, 2009
- 17
I have a 76 Johnson 85 hp. I have rebuilt the carbs, changed coils, power pack, fuel lines. I tried spark test with the plugs in and it won't fire on the right side but it does with the plugs out. The guy at the marina said something may needed to be adjusted under the flywheel. Any idea what this is? What size nut is on the flywheel so I can by the socket and remove. I do have a inpack wrench. It will start if I chock it. it will idle on high and when I turn it down it dies. I can get up to speed sometimes on the water and it will just stop.
