Capt. Willie
Thread starter- Joined
- Jan 1, 2015
- 34
I just got this boat-cheap, and it's the first I've ever owned. I'm a carpenter/remodeler, so I have the skills, if not the 'boat-knowhow'.
The boat sat idle and uncovered in a friend's yard for the past 10 yrs.
The Hull is in fairly good shape, BUT the interior IS trashed...the sun cooks the heck out of plastic, etc. here in Vegas.
(I'm a new member, and I'm going to check the 32 pg. Topic I've seen here on this same boat's restoration.)
It has a Volvo "170" inline 6 cylinder, w/ 3 one barrels, and a '280' Penta Outdrive
I cleaned plugs, points, and dist. contact points, etc. and she started right up, and runs great!
My questions are: I'm searching for a service manual for this boat., but NO luck so far....any ideas?
The Trim function doesn't work, and there has been some rewiring that was done long ago. Does anyone have a wiring diagram for this Boat/model?
Also, I have a steering problem, and I'm fairly sure it's a problem w/ the cable, any ideas on where to find one? (I took apart the steering mechanism, and the gears etc. looked good, but there are some cracks in the outer cable housing, and the steering does function, BUT will only turn from center to the left, and then back to center where it jams up.)
Any help would be appreciated, thanks.
