Possible binnacles and gauges - 2017 Yamaha F150XCA
wpchrist
Hello all,
I just bought a used 2017 Yamaha F150XCA. I put it on my 2005 Hurricane deck boat. I also bought the boat used with no engine.
I have a couple of questions
The Harness from the binnacle has a round ten pin connector on the engine end. There are also two square four pin connectors. I looked extensively on the engine but did not find a round ten pin connector, just a square yellow connector with about 14 wires. The binnacle is the original sidemount.
Is it possible to use this binnacle and harness from the binnacle to the engine or do i need a new binnacle and/or harness?
The gauges are analog but new. The picture shows the old gauges.
Can I use these analog gauges with this engine? The dash configuration makes it awkward to try to fit any other type gauges.
Thanks in advance for any help!
You need the boat side harness that goes between
