Hey all; Have 2000 90 hp merc. 2-stroke. Carbs rebuilt 6 months ago , boat has been running fine. Other day smelled gas under motor cover and saw gas leaking out the front of lower carb, even with motor off. Took carb off and apart, nothing appeared out of the ordinary. Did a bench test to check the float operation by filling carb with gas and blowing as hard as i could thru the gas line hose, it held it's own . I assume float is ok. Put back on and gas still flowed out lower carb. Not so much at high idle, but at idle and continues after shut down. Is it a bad reed valve ? Thanks for any input
