model number. (or model and serial number). don't think it matters terribly what spray you use, but don't overdo it. and don't put the plugs back in and pull it over (it could fire). I would take a compression tester (screw in type), and a spark tester. Spray in the lube (can use a little fogging oil if you like) to protect the cylinders, as you wanted to do, then test for spark. Attach the tester away from the back of the cylinder (again, potential ignition). Pull each cylinder over three or four times testing for spark. Then test each for compression (comp. test will be affected a little -- improved with the lube remaining in there, but that's ok.) You are looking for compression roughly the same in each cylinder (w/i about 10%). Pull the motor over five or six times for the comp test until the needle stays steady (both plugs out). Some will recommend grounding the open plug wire or wires when cranking. I don't do that.
Anyway, that's what I would suggest, if more comfortable with some testing -- whether you run the motor or not. Maybe skip spark testing if the motor is run for you, and runs smoothly, However if running, can pull off plug wires individually to see if there is a change in rpms (maybe stalling). If no discernible change, the cylinder you are disconnecting isn't firing.
so you need a spark tester, compression tester, plug wrench, and a pair of leather gloves. and your gas line, I guess.
edit. Don't fire the motor without dunking the l.u. in water, or using muffs. Which reminds me, take along the muffs. AND, if running, do it without the hood so you can check temp (heel of hand on top of head -- the motor's head.... or get an infrared temp gun (fun, and you should have one anyway)). Shut it down if it's too hot to touch.
