Chris_94_Sprint_TX
Thread starter- Joined
- Jun 1, 2013
- 226
:frusty: :frusty: :frusty:
I did a complete tune up, changed plugs (gapped at .035), wires, cap, rotor, and point (all parts were from NAPAs marine catalog all in all about $1,000 in parts) and now when I take the boat out it runs fine for a few minutes then the points close up and it starts sputtering, surging, and popping through the carb. I didn't do anything to change the timing of the motor. I installed the point at the high lobe on the distributor shaft and it idles fine but then when I take it out it runs strong for about 15 minutes or so until I make a turn then it bogs down and starts sputtering, surging, and popping, if I come all the way off the throttle it stalls out. It also seems to run a little hotter than before too. Motor is an 85 Mercruiser 3.0L 140. Its done this to us twice and its starting to get annoying at $4 just to launch the boat for 15 or so minutes. Is there some break in procedure I am skipping here? Could bad gas be the culprit? I also changed the prop, installed a battery selector switch and a new fuel sending unit.
Any ideas guys, I'm loosing my mind here and my kids and niece and nephew are getting upset cause they think we're going tubing but end up getting let down.
Chris
Chris
