Turtlelips
Thread starter- Joined
- May 14, 2004
- 46
I have a 1985 40 hp Evinrude. I can't seem to figure out what the problem is. When I put the shifter in full throttle the rpms go up for a couple of seconds but then it just dies down, but motor stays running at about 6 mph. I checked my fuel supply for any leaks and replaced all the hoses and clamps. I recently changed the water gasket as well as the thermostat. The thermostat didn't seem to go in the hole very well, could that cause water flow problems? I also recently had my carbs completely cleaned and I also replaced the starter solenoid, fuel pump and fuel filter. If anyone has any suggestions on what the cause may be please help! Thanks in advanced
