Power tilt will not raise Yamaha 2000 115hp v 4 not oil
kyong1
power tilt motor work and attempted to fill but won't raise 115hp 2000 yami
TyeeMan
Master Chief Petty Officer
So what you're saying is, the power tilt motor works, you can hear it run? But it does not raise the motor.
You attempted to fill with oil, , was it full already or did you not figure out how to fill it and you don't know if it has enough oil in it or not?
kyong1
The oil seems to be contaminated after filling the reservoir, It was working fine before that . Now it won't raise. It also seems to be full. I do not see any leaks. I would now go to the next step disassemble. However I'm not convince it needs repair.
Bob_VT
My first guess is an air pocket ............ contaminated oil not good. Drain, refill and get the air out and it might start working again properly.
Silvertip
You might get much better help if you posted your issue in the YAMAHA forum.
kyong1
In the process of disassemble and recheck. Thanks:eagerness:
kyong1
Well while removing the screw cap it seem to come lose in some form or other.. so I clean the cylinders.Fill with new atf tighten all and bleed. Now all is well. 😂
crazy charlie
Good news!! Did you know that there is a "release" screw on the port side close to the hull that you can loosen and raise the motor manually and tighten screw when motor is fully raised.This would make the filling process easier and give you max capacity in resevoir.Charlie
