Power trim will not work
acuraguy81
I have power but no power trim. Never had any issues before just all the sudden. its a 1990 chaparral 2050 with a omc 4.3 liter. Any idea's? PS i tired to jump the contacts to see if there was a wiring issue no luck there.
RIDEPATE
Re: Power trim will not work
On my (93 5.0 OMC) there is a rubber connector left side high, it has 3-wires, I bumped loose changing the Alt belt, white-red striped,2-white green striped, no noise, no click, nothing. Found it, plugged back together, (was not tottally loose) bam, problem solved.
acuraguy81
i tried all the wiring even jumped the connections to see if it had power. im guessing the pump just all the sudden went out for some reason.
Don S
Not sure, but I think this is the setup you have.
  • OMC-VP relay.pdf
acuraguy81
i took it all apart and cleaned the motor and reinstalled it and it works good. But now i can not get it to lift or lower the drive, it did take about a quart of fluid! is there air in the system and if so how do i get it out?:facepalm:
acuraguy81
bump? This thing is weird not sure why its not working. The motor sounds great now.
chriscraft254
Mine has a screw adjustment on the side of it to be able to manually lower or raise the outdrive. If this screw is not adjusted all the way in, the outdrive will not raise or lower by way of a powered switch, but it will still make noise when the switch is pressed. Not sure if yours has the same release screw, but I would check to see.
acuraguy81
It does have the screw I used it to bleed some air out and was able to get more fluid in then i tightened the screw back in. The drive still will not raise or lower. Im lost here..
acuraguy81
I can not get this unit to pump fluid help please. All seems good sounds good just not pumping?
