pre alpha match
trm
I have a Mercruiser pre alpha outdrive (SN# 2361794) eight spline verticle driveshaft mated to Mercruiser 120, and I have read dozens of posts here and elsewhere, trying to determine what newer (read parts available to repair) lower unit will mate with the upper. One post suggested that the Alpha 1, Gen1 might work. I've learned "might" isn't good enough.
Also would like to know what newer complete unit (upper and lower), if any, will mate with the old, current bellhousing.
My current lower unit is trash and the fish are biting :)
Any information is greatly appreciated,
trm
Re: pre alpha match
The pre-alpha only matches the Alpha One Lower Unit. The Bravo or Gen do not match!!!
trm
Re: pre alpha match
Thankyou frostywalrus. Could you explain your reply more completely.
Are you saying the Alpha 1 lower will fit my pre alpha 8 spline upper? Are you saying that I could use a good pre alpha 8 spline lower with the Alpha 1 upper?
Re: pre alpha match
Hey there, here is a site that may give you some insight on what you are asking.
http://www.mercstuff.com/drive_id.htm
It will tell you what drives are compatible with each other.
What exactly is wrong with the lower unit u have at the moment?
Just curious cause I have been looking for a Pre-Alpha Lower Unit Housing.
Good Luck
trm
Re: pre alpha match
Thanks frostywalrus,
I lost reverse gear and mechanic said that previous owner had used a torch somewhere and deformed thread on a bolt preventing opening of unit to repair, i.e. trash.
Re: pre alpha match
Nope,... Your old upper,+ lower are pretty much Worthless...
But,...
You can swap on a Complete Mod.1 drive, or R drive, or MR drive, or Alpha 1 drive....
trm
Re: pre alpha match
Thanks Bond-o,
Will those units fit to the pre alpha bellhousing I have?
