Pre load pin on top of driveshaft
jslu
1987 MERCURY 35 HP
Serial No. 0B177575
The pre load pin on the top of my drive shaft has been erroded by rust by approx 20%.
My initial thought is that it would still be servicable considering the downward forces placed upon it. The spring is operative.
How can I remove it to replace it if I so desired? Is the holding mechanism screwed into the top of the drive shaft?
Or what????
Thanks,
John
Faztbullet
Re: Pre load pin on top of driveshaft
If you look real close you will see it peened in place and it can be removed with a dremel tool. Be careful as this thing will shoot out with the force of a .22 Hi power shell!!!. You will need a press to hold it in place while you re peen it after repair.
jslu
Faztbullet,
Thanks for the heads-up on the danger of removing the pre-load pin. Having been a long time fan of .22 calibre firearms, I can appreciate the danger of an unwanted discharge event.
That being said, I'm going to go with the compromised rusted pin as serviceable. Risk vs reward theory !
Thanks,
John
