I've spent considerable time reading through the great threads here, but still have a question regarding the best and most efficient (not to confuse with 'easy way out', but avoiding an engineering procedure also!) method to add anti-freeze to my raw water side of a closed cooling system for winterizing and corrosion resistance. I've read the ADULTS SECTION and appropriate STICKY NOTES. Particularly #14 of ADULT SECTION WINTERIZING. Have manuals and have read them 3 times.
I am confident on removing water with compressed air via schrader valve and manual drain points. Getting the proper anti-freeze/corrosion resistant solution is introduced into the system is my main concern/question.
I have a 2005 Formula 260SS with Mercruiser 496 Mag HO DTS, s/n OM680176. It was a salt water boat (150hours) previous to this summer (2009) and now operates in Michigan and therefore facing a cold winter stored unheated/indoors.
It's the procedure I'm looking to gain knowledge/advice on. Thank you.
