Priming Bare Aluminum
Cox
I've read a lot on iBoats about using a Napa #7222 to prime bare aluminum. I found this today at HD. Is Cold Galvanizing Compound the same thing?? If so, I figured I'd be better off using it since I'm using Rustoleum paint also.
Re: Priming Bare Aluminum
Nope,... That leaves a coating of galvanize on Steel... Helps slow Rusting...
Search the Rustoleum website,... They market an aluminum primer,+ HD can order it by part#...
ezmobee
zinc chromate primer which I've heard is available at Napa. It's green. A light dusting of the stuff is apparently all you need.
Cox
Thanks guys. I'll look into the Rusto product or else go with the Napa deal.
EZ, been following your project.....Great stuff!!!
ezmobee
Thanks! Hey if you want a great pictorial of the ZC primer in action, check out Rickairmedic's Jupiter restore.
