Re: Priming
I do not know if you have an (A) electronic choke or a (B) fuel enriching priming valve. In either case, you could have someone push in the key while you check things out. A -- do the choke plates move well? B -- with the hose pulled off at the outlet, does the valve squirt gas? Of course, pushing the key in for more than 3 seconds or so will flood the motor before you can say Noah -- based on my own experience.
