Hi all, Haven't been on in awhile but have some interesting info. Looked but don't know if this subject has been posted previous. My neighbor just bought a 2007 G3 22' pontoon. Boat sat mostly on trailer by previous owner until it was used to go out on. My neighbor brought it home and put it in the water tide it to his dock and within 2 days it started taking on water. Seems that the pressure treated bunks, which as of 5 years or so ago are treated with COPPER , ate thru the the aluminum logs. There is a chemical reaction between the copper and aluminum toons , wet bunks being the catalyst. The logs have small pit holes thru them wherever they sat on the bunks. Apparently the previos owner was not aware because they would take boat out of water after every use. I ,being an siding contracter have had this problem with capping p.t. with aluminum coil .It will eat it up in no time, as if acid was pored on it. To do it to .080 thick aluminum is amazing. Most of the new p.t. have stickers that warn against use with aluminum. Thanks and beware
