Problems engaging the drive
CarrierSquid
I have a 165 HP inline 6 I/O that starts just fine but when you go to engage the outdrive the motor dies. I have been told that i need to move a cable closer for the drive but before i do that i want to know if there are any other ideas that anyone has.
porker99
Re: Problems engaging the drive
I have had that problem Its the shift interrupted switch that is messing it up. Or u need to replace the lower unit cable. But it sound like the switch went bad and u need to get the newer stlye
porker99
Its going to be on the transom right beside the exhaust u see back there were ur two cables come to gather its going to look like an arm style.
CarrierSquid
ok and the arm is what i replace? any idea the cost of this?
CarrierSquid
i did forget one probably important part on this... the prop does spin when you engage it but then it dies... same thing??
Rscardina
the shift interupt swith is just under the arms that your throttle and shift cabbles attach to at the engine. its got a couple of black wires on it. mine was on the left side of the engine just above the heat exchanger, your may be different
I had this issue a few years back.. it ended up being some cable addjustment issues. if your cables feel smooth and you dont have to apply too much pressure on them then i would think the cables are ok...if its a bit of stiffness and not smooth then you may have a cable hanging up causing too much tension and therfore breaking the switch
if in your case you had no issues and it just started the i would take the dog house off and while you have your buddy put it in and out of gear..watch what the plate does.. you can do this with the engine off.. its just to see if your switch is engaging before the shifting actually happens. i wish i had a pictuer to show you, its really easy to tell.
CarrierSquid
why do i have the feeling that this is going to be more of a pain than i want it to be??
CarrierSquid
ok found out it is more than likely the switch.... had a couple of guys look at it and they said thats what it was. i just hope that is all it is...
CarrierSquid
oh forgot to ask... for those of you that have replaced this switch... how hard is it to do??? is it as easy as taking the old out and putting the new in?? or is there more to it than that??
CarrierSquid
Got it fixed.... turns out it wasnt the switch but it was the lower shift cable assembly... and the only problem was the guy who had it measured the cable attachments wrong.... they were supposed to be 6 inches and he had them at about 7 1/2 inches... easy fix...:D
