brehlers69
- Joined
- Feb 27, 2005
- 67
I know you cant make ice cream out of sh@# but i dont think im trying to do that this time. I cant keep the 1948 9.8 johnson sea horse running in the barrel. I disassembled the engine and cleaned it out the best i could and inspected every port to make sure it wasnt plugged. I replaced bolts and cleaned out 50+ yrs of carbon build up. I thought for sure it would run this time to no avale. It will run fine on the bench but the minute i put it in the barrel it shut down. I also noticed when it was apart that the block wasnt getting any water which the prop is responcible for delivering. I blew out all the lines and was getting air flow in return so I know the system isnt blocked. Any quesses on the problem of lack of water and zero performance in the barrel would help. I tried to mess with the idle pins on the carberator and it did not help.
