Prop Blueprinters
TOM MELTON
Hey guys,
It's been a while since I've been on the forum but, I have a quick question and I am sure DHadley (or anyone else) can answer this one. Who is the absolute best prop man or shop around when blueprinting for best all around performance ?
Thanks Guys !
Tom
D
DJ
Guest
Re: Prop Blueprinters
I'll move this to Prop Questions. That's where the prop. gurus hang out.
walleyehed
Mark Croxton or Rich Boger in general..
What Prop are you wanting Blued?
TOM MELTON
Hey Walleyehed,
Thanks for the reply I'm not sure what prop to use I spoke with Rich Boger and he said either a Tempest or another Raker. I heard about Mark somewhere but am not familiar with his work . Can you speak from experience on either mans work? Thanks
Tom
walleyehed
I've had a Raker done by both...
Boger Done a 20P for me and Croxton done a 22P.
Boger is real good with the Rakers and will only do OEM props....Merc, OMC/BRP, etc..he doesn't want to touch any Turbo, Ballistic, etc. type props-aftermarket, if you will.
Croxton is Excellent with anything he touches.
I would also consider Merc Racing division if staying with a Merc prop.
Dhadley
Agreed, all those guys are good. Most have specialties as Kenny mentioned. Sometimes it depends on what type of hull you have and what you're looking for. A buddy had a DAH (Don Henrich) prop on a Hydrostream that got trashed. DAH redid it and it worked almost as good as new but he said it was done. He hit something again and I had him send it to Mazco. John redid it and it worked better than ever.
TOM MELTON
Thanks fellows for the quick reply, Which prop should I use? The Raker or the Tempest? The engine is a 150 FastStrike on a 185LS Tournament HydraSport bass boat. It will run out about 64.5mph(gps) @5400r's on smooth water but not stable at all. Itvents or cavitates around turns and porpoises and sits low in water to me. I would like to see 70mph or more if possible with more lift and control. I know I want it all! Thanks Tom
arks
Hey guys,
Thanks Guys !
Tom
Find an authorized PropScan shop. They use computer analysis to dial in a prop- and it works.
Dhadley
Are you looking for an out-of-the box prop (repeatability in case of damage) or a full custom built exactly for your boat?
Turbo1
DH, would Mazar build him a specialty?
wca_tim
Although I've not used them personally, I've heard good things about Throttle up in Michigan. Might be worth a call
TOM MELTON
Hey D,
I'm just looking to get a prop dialed in to my boat . Hopefully I won't need repeated replacement but there is always the unexpected right?
Thanks Tom
TOM MELTON
Thanks I'll look them up and chat with them!
TOM MELTON
Do you know who is an authorized prop scan shop?
Thanks Tom
Dhadley
T-1, yes Mazco does build boat specific props. The last on he built for me was for a Hydrostream Vegas. I told him what I was looking for and he shipped it. Turned out it was a RE-4 29. It didn't do what I had asked for. It was better.
Dhadley
John Mazar owns Mazco Propeller. He modifys existing props and makes a line of his own. He's one of the oldest custom prop shops that I know of.
We still don't know exactly what you're looking for or what kind of boat you have. Are you looking for a $700-900 race prop or to get a good box stock prop and have it labbed or just looking for the best out-of-the box prop for a particular rig?
