Home Cookin'
Thread starter- Joined
- May 26, 2009
- 9,715
my prop came off when I was finally able to get a restoration project in the water! Luckily it was at the pier, and at high tide, and later a diver retrieved the prop, but I still lost the nuts, bushings, etc. and had to put the boat away another 2 weeks.
When shopping online for the parts (1972 motor) I was surprised to see that the nut kit had one of those nylon-threaded lock nuts rather than a castle nut, so I was planning to get a castle nut anyway. Couldn't find everything at the boat junkyard. On advice I double-checked and sure enough my shaft is not drilled out so I have to go with the nylon, and have ordered the kit.
Obviously the old one failed and the consequences could have been a whole lot worse--certainly more expensive. When it first happened I blamed myself for removing the cotter pin several months ago and forgetting to replace--but it now appears that the nylon failed--maybe b/c i didn't use the motor for at least a year maybe two?
I've never lost a prop. I've also never had one with a nylon lock nut and I'm not happy about it. Even my old evinrude's plastic cap was secured by a cotter pin.
I also am not one who will inspect every nut and bolt literally from stem to stern before, during and after every boat trip. I use most of my boats frequently and expect more out of them; they are there to serve me and not the other way around.
Is this a common problem? A design failure? any solutions? maybe a double nut? Not sure I want to drill my own hole, but...?
1972 Merc 200 (20 HP) but it could be any motor rigged this way. i don't know if I could find a second one at the hardware store threaded for the shaft anyway.
