Prop Selection 22'2" with 89 Johnson 225
Teapot
Trying to dial the prop in for Fuel ecomony and bow lift
currently
3 blade 14 1/2 X 19p dinged up a bit
wide open throttle 5200 rpm WOT seems low?
top speed 37.5 mph
about 1.3 miles per gallon at vering spedds with a 6gallon tank and gps for
miles covered
i like cruise in the 25 to 30 mph 3000 to 4000 rpms
fish in galveston bay and near shore gulf of mexico
was thinking a 4 blade 14 X 20p or ? ideas input is welcomed i dont want to waste all my money on the gas pump would rather buy new fishing gear:redface:
Teapot
Dhadley
Re: Prop Selection 22'2" with 89 Johnson 225
That's usually the pitch we use on that combo but you're down on top rpm by quite a bit. Are you sure the motor is running right? How's the set up? Can the motor be raised any?
Teapot
How should the foot line up to the bottom of the boat?
The horizantal fin even with the bottom of the boat? or ?
Thanks Teapot:rolleyes:
Teapot
here is a pic of my setup
engine is all the way down
http://gi168.photobucket.com/groups/u184/K15328JXO4/DSC00335.jpg
reffence to how the horizantal fin is to bottom of boat engine all the way down
http://gi168.photobucket.com/groups/u184/K15328JXO4/DSC00336.jpg
and about where i run at
http://gi168.photobucket.com/groups/u184/K15328JXO4/DSC00337.jpg
got lots of room to move up just just have to move to different mounting holes on engine
so thoughts are the engine is to low?
Thanks teapot
hwsiii
Teapot, your motor is wayyy too low, and Dhadley will get your setup right for you.
H
Dhadley
Yep, looks low to me too. Can you post a pic of your prop?
Teapot
Dhadley
You may be able to go up a little with that prop but probably not much. Looks like the tip cup is pretty well worn. I might be inclined to try it up a little but if you were considering another prop I'd probably get the prop first.
Teapot
so what would you recomend for size and pitch? i was thinking smaller diamter and higher pitch currently it has a 3 blade 14 1/2 X 19p. have read that a 4 blade has better mid range ecomony and bow lift.
input is welcomed
Teapot
Dhadley
We've had good good success with the standard Stiletto or Turbo 3 blades on those boats without jackplates. With jackplates we use the Turbo 4 blade.
Teapot
Had my buddy take the helm while i was looking at the foot the Horizantal fin is underwater when running by little over a inch i would say. Figure i will get a manual Jack Plate and try to dial in the corect engine hieght. Could that be the reason for the low WOT rpm still 5200 is all she has ideas?
Teapot
Dhadley
At this point I might start looking at the motor itself. Raising the motor is going to / needs to happen but while you're establishing your baseline you need to make sure the motor is giving you 100%. Even if the motor is a little low there's a possibility it should be at more than the 5200. A healthy 3 liter open deck looper should turn a bit more than 5200 with a standard 19" prop on that boat even if it's low.
There may be other factors but now would be the time to confirm the motor is all it can / should be.
Teapot
Raised the engine 2 bolt holes not quiet enough though 1 more should be it.
Engine WOT rpm unchanged considering a carb clean/rework fellas at alvin marine want 600 for the service . Went through the entire electrical system recently on this thread http://forums.iboats.com/showthread.php?t=368353 so carbs will be the next step right?
Thanks:D
Teapot
