propeller change out - EXTREME NEWBIE Question - Need Help!
cparkerc
I am switching the prop on my 1970 25 hp Johnson. If I tighten it to the point where it is snug, I am having problems getting the cotter pin in. If I back it off a half turn, I can get the pin in easily, but there is some play. Is that ok, or should it be snug? Hope that makes sense.
Thanks
CparkerC
geoffwga1
Re: propeller change out - EXTREME NEWBIE Question - Need Help!
Just put the pin in where the holes line up,it's not supposed to be tight up to the housing or it would bind.
