DYLBOSS
- Joined
- Aug 11, 2009
- 161
I'm trying to figure out if my tach is correct. I bought an hour/RPM meter and have installed it. I have one wire wrapped around plug 3 a bunch of times and a ground going to the engine chassis. Tried 2 different spark wires too with the same results. So far things seem to be way out of wack. The meter tells me to configure it with 1 of 3 settings:
1. Spark plug fires twice per revolution
2. Once per revolution
3. Every other revolution
Not a mechanic by any stretch, and just trying to get to the bottom of this. Does anyone know what setting this should be on for my motor? So far, option 1 has produced the most reasonable results with 1300 RPM at idle. The others are 2k+.
When I looked online at the Merc engine specs it said that it should be in the 650 range. Is that right? Sounds very low.
I should add that I tried this in my driveway with muffs on, if that makes any difference.
Thanks.
Thanks.
