Protecting drive from salt?
RCSConstruction
If I wanted to go above and beyond simple flushing and salt-away what would I use to protect my drive/exhaust from saltwater? It has a closed cooling system so I am not worried about the block.
Is it worth the trouble or is salt-away just as good as anything?
Also, what do you use to spray around the motor, stainless hardware, bolts etcc to protect from corrosion?
Is WD-40 ok to fog around?
I did a search and found some different suggestions but nothing seemed to have a general consensus.
Thanks
Coors
Re: Protecting drive from salt?
crc makes a good anti-corrosion; $7 but it works. Ace hardware has it.
RCSConstruction
Thanks coors.
What about the drive? Thinking an active anode system??
bruceb58
Is your boat moored in salt water?
RCSConstruction
No, pulled out and flushed every time.
I just see corrosion in the water passage when I pulled the drive and it got me thinking...
bruceb58
If you aren't moored, you don't really need an active anode system.
friendly_jacek
I keep mine on trailer and flushed after every use and saw the same thing (especially near the water pump) when I replaced the water pump in 3 year old drive with little use.
I guess water stays in these passages and takes forever to evaporate. Poor design if you ask me.
