agallant80
- Joined
- Oct 25, 2010
- 2,328
Has anyone pulled a Bravo3 off by yourself? Is it doable or are you just asking for a disaster if you don't have someone to help you move it.
Is it bad if I leave the drive off of the boat for a few weeks or a month?
It's only a 2 man job if you have to "muscle" it around with no other assistance (hoist, lift, stand, etc) to keep you from hurting IT or yourself!I want to pull it off to check the alignment only issue is the boat is at a storage lot so I will have to bring someone with me if its a 2 man job. I may take it off, check the alignment and come back with a friend if I have hard time getting it back on.
So when I get the drive off I should inspect the gimple (see how smooth it is) and check the alignment and u-joints. Anything else? Also what grease should I use? I know there is Merc spline, prop, coupler and what not grease. I would like to just use one for all.
