According to the Evinrude technical literature (E35ECTS), one should not pull the flywheel with an edge type puller because it is "certain" that the flywheel will be damaged. Is Evinrude referring to damaging the teeth that the starter engages? There is an edge above the teeth that accommodates a pull rope (in an emergency). Is there any problem pulling from this edge? What gives here?
