Pulse Limiter
sfc
In testing the Pulse limiter Inlet on my VRO, I applied air to the inlet on pump. It would not hold pressure as required by test. I soaped and air bubbles coming out around housing where fitting is attached. No way to repair, looks molded or glued. I assume this would prevent the fuel pump from working? Engine will hardly run without pumping primer ball.
There are check valves. in the air motor housing.------One lets pressure to one side the other lets lower pressure to other side.
Faztbullet
It tis bad..either replace with newer OMS pump or standard fuel pump depending on engine type.
