Put new seals in the water pump, now no forward gear
jerad_s
9.5 johnson. What did I do and how do I undo it. I had forward before I tore it apart.
Daviet
Re: Put new seals in the water pump, now no forward gear
Do you have the connector for the shift shaft installed properly, the bolt through the notch in the shift shaft?
jerad_s
yup, im thinking there must be a gear that the LU and the shift lever on the motor must be in when you connect them. For example, the LU in reverse and the powerhead in reverse also.
jerad_s
bump this back to the top
Daviet
If you have the connector installed properly the linkage will be in the proper gear.
jerad_s
bingo, I didnt have it far enough up. I realized the notch has to be in place for the screw to fit in.
