I have an '89 Marlin Cobra 21' with a 350 Chevy Mercruiser and Alpha One. The boat is new to me and not seeming to be running quite 100%. I sprayed the air bleeds and carb in general with carbcleaner and readjusted the idle. Much better. It had the throttle plates opened so far the idle screws did nothing, and one was open about 5 turns. Anyhow idle is much improved now though still seems rich. Idle screws are still not as responsive as I would expect. I wonder if the bowl plugs are leaky?
In any event, my main issue at the moment is that the boat does not have the top end I would expect. When I open the throttle the last 1/4 of the way it bogs noticeably and won't pick up. If I back off the throttle a bit the power comes back on. Seems like a bad lean bog once the secondaries open up. I've not done much with Quadrajets so not sure how to proceed. Any thoughts? Perhaps secondary air valve adjustment?
Other option is to forget the Quadrajet and go with something like an Edelbrock Performer and a Holley. Thoughts?
