Hello everyone, I have questions regarding a 3.5 gallon metal yamaha outboard gas tank. I needed a tank to get an old Ted Williams 7.5 going and found the tank and fuel line/bulb on Craigslist for $35.
Anyway, it won't pump gas up to the motor. It has the omc type conector on the tank and goes right to the carb. It is leaks on the tank where the fuel is conected, and the float seems to be stuck down. If I need to replace that pump or connector I have no idea what it's called. A little help, I'm a novice outboard guy, since the only other motor I've owned was a Tanaka 300 (which is closer to a weed eater).
