Question I never gave much thought about?
suzuki40
I know how a 4 stroke crank gets its lubrication.<br />But how in the world does a 2 stroke crank get it's lubrication?<br /><br />Suzuki 40
lakensea
Re: Question I never gave much thought about?
The oil is mixed with the fuel which all passes through the crankcase on its way to the combustion chamber.
suzuki40
I thought about that...but then I wondered, why would you run gas over your crank for lubrication? I thought that the bearings may have been self lubricating? but what you said could only be the way it would work.<br /><br />Suzuki 40
JasonJ
Most 2 stroke cranks run on either needle or ball bearings, so the oil that is in the gas is enough, and the pressure in the crankcase force the gas/oil mix into all the bearings. A four stroke crank bearing relies on a bearing system that uses oil as the actual bearing by suspending the crank in a thin layer of oil.
roscoe
You have to thank SLOOPY for that one, I dug it up from one of his old posts.
SeaMasterZ@aol.com
I believe it was Joe Reeves that said that there is a small hole in the piston that forces lubed intake charge into the bearing, "force lubricating" it<br /><br />I cant be certain tho, if ya didnt say that Joe, sorry, but I tend to take your words as if they were written into stone by fire, lol
