question re: primer application/for Bond-o
2cycle
Through another thread, it was noted that anything aluminum on my Merc 1500 will need zinc chromate primer. I had already primed the cowling with regular Rustoleum automotive primer. My question is, will all of that need to be sanded off down to the metal, or can I spray the zinc chromate over it? Thanks!
Boomyal
Re: question re: primer application/for Bond-o
If you want the anti-oxidation benefits of the zinc chromate, it has to be applied directly to the bare, acid washed aluminum.
2cycle
Boomyal - thanks, that what I needed. I guess I've taken up this new hobby called... sanding:'(
Saskatoon2005
Master Chief Petty Officer
Just use a chemical paint stripper. One that is safe for outboard cowlings...LOL! Good Luck!
Patrick
