Re: Questions for getting engine started
Tried directly from battery to starter and it didn't get enough juice to turn the fly wheel.<br /><br />Took spark plugs out and turned flywheel by hand. I can turn it fairly easily but it still seems to bind at least once every revolution. Is that normal? Should it be harder to turn at some positions?<br /><br />Tried turning engine over without spark plugs and it turned fine. Got enough power to turn flywheel for as long as I held the key. Put plugs back in and tried turning it over and it still turned fine. Then after a couple tries of turning it over there wasn't enough power left in the battery. Put the battery back on the charger and it showed that is was about 25% charged. I took my battery back today and got a new one. I will try that one tomorrow.
