Quick Carb. Question
Kaykatz
I installed carb. kits on my 1971 Johnson 50hp outboard. The kit came with a little metal hook to attach the needle to the float. When I took the carbs. apart, they did not have the clips, so I put it back together without the clips. I won't be firing it up till the spring - so should I leave it as is, or pull the carbs off again & install those clips?
boobie
Re: Quick Carb. Question
They will probably work with out the clips but if it was my mtr I'd install them. Less chances of the needle sticking in the seat.
lindy46
Rubber-tipped needle in the new kits can stick if you don't install the spring clips.
Kaykatz
Thanks guys, I just wasn't sure if these carbs were meant to work better without the clips. I just pulled the carbs off again & installed the clips.
